PowerTracks Pro Audio is a full-featured, multi-track music sequencing and digital audio recording program. PowerTracks Pro Audio includes powerful and unique features such as: The Audio Chord Wizard, which automatically and accurately figures out the chords from MP3/WMA/WAV audio files, the TC Helicon Vocal Harmonizer to add harmonies or pitch correct your audio tracks, and RealDrums which allow you to instantly generate audio drum tracks that are real recordings of drummers - not single drum hit samples but full recordings lasting 1 to 8 bars.
New Features in PowerTracks Pro Audio 2017:
• The new PowerTracks Pro Audio 2017 includes many new features and enhancements!
Music XML (notation export/import) has been enhanced.
• Guitar tab, bends, hammer-ons, and pull-offs are imported/exported.
• Chord symbol are now more accurate when importing from XML files that were created in major notation programs. Chords match better with more complicated chord types.
• When exporting chords to XML, the chord format written to the XML is now more compatible with other major notation software.
• Exporting of more complicated chord types has been improved.
• When importing XML, beats containing triplets will automatically be individually set to triplet resolution when appropriate. If the song contains more than 20 % triplets, the overall resolution in notation window will also be set to triplet resolution.
• Exporting of 8th note triplets to XML has been improved. The 8th note triplets that involve a rest are now being exported to XML.
• When importing XML, double sharps/flats in XML will now be converted to a compatible single flat or sharp accidental so that the correct pitch is imported into RealBand.
-Just Install
Title : PG Music PowerTracks Pro Audio 2017 Build 3
Xem thêm chủ đề liên quan:
