iuvothangban
µTorrent 3
Super fast! Ultra light!
µTorrent is an efficient and feature rich BitTorrent client for Windows sporting a very small footprint. µTorrent was designed to use as little cpu, space and memory as possible while offering all the functionalites expected from advanced clients. With BitTorrent, you can download files faster and contribute by sharing files and bandwidth. Most of the features present in other BitTorrent clients are present in µTorrent, including bandwidth prioritization, scheduling, RSS auto-downloading and Mainline DHT (compatible with BitComet). Additionally, µTorrent supports the Protocol Encryption joint specification (compatible with Azureus 2.4.0.0 and above, BitComet 0.63 and above) and peer exchange. µTorrent was written with efficiency in mind. Unlike many torrent clients, it does not hog valuable system resources – typically using less than 6MB of memory, allowing you to use the computer as if it weren’t there at all. Additionally, the program itself is contained within a single executable less than 750 KB in size.
Various icon, toolbar graphic and status icon replacements are available, and creating your own is very simple. µTorrent also has support for localization, and with a language file present, will automatically switch to your system language. If your language isn’t available, you can easily add your own, or edit other existing translations to improve them!
Features of “µTorrent”:
µTorrent 3.3 Release highlights:
Changes in Version 3.2.1 beta (build 27605):
Changes in Version 3.3 alpha (build 27612):
[SUP]
[SUP]
[SUP]
• Multiple simultaneous downloads
• Smart bandwidth usage
• File level priorities
• Configurable bandwidth scheduling
• Global and per-torrent speed limiting
• Quickly resumes interrupted transfers
• UPnP support (WinXP only)
• Supports popular protocol extensions
• Trackerless support (Mainline DHT)
• Localized to different languages
• Typical memory use less than 6 MB
• Incredibly small: about 600 KB
• Disk I/O system completely rewritten. Now multi-threaded and high performance. It will take advantage of multiple disks, perform better with even just one, and no one disk job can block everything (e.g slow network blocking local I/O, or allocating files)
• Auto-labeling and per-label download directories (Preferences -> Label)
• Search items in Advanced preferences
• Paired device removal
- Fix: Seeing while streaming in Chrome
- Change: Disk I/O error logging
- Change: Disable unbuffered I/O
- Fix: Broadcast new UPnP IP when switching networks
- Fix: When downloading magnet metadata, don’t start torrent unless user chose that option
- Fix: Resetting columns in detail listview would crash
- Fix: Crash when peer cancelled a piece
- Change: net.friendly_name (upnp network name) advanced option
- Fix: Crash when writing magnet torrent file to disk
- Feature: Advanced Settings filter
- Feature: Convert http trackers to udp by default
- Fix: Incorrect http requests were causing some RSS feeds to not download
- Feature: introduce disk job timing graph
- Fix: last shutdown hang
[SUP]
[/SUP][SUP]
[/SUP][SUP]
[/SUP]
[B][URL="http://download.utorrent.com/latest/uTorrent-3.3.exe"][COLOR=#008000][U]Download[/U][/COLOR][/URL][/B] [B]| Windows | µTorrent 3.3 Alpha[/B]
[B] [URL="http://download.utorrent.com/latest/uTorrent-beta.exe"][COLOR=#008000][U]Download[/U][/COLOR][/URL][/B] [B]| Windows | µTorrent 3.2.1 Beta[/B]
[B] [URL="http://download.utorrent.com/uTorrent.exe"][COLOR=#008000][U]Download[/U][/COLOR][/URL][/B] [B]| Windows | µTorrent 3.2 Stable[/B]
