hi all,
first of all I am sorry about my english, if you can't stand to read just click attach file
Support questions from members who have not marked this as installed - as same as - who have marked as installed will be considered high priority. I believe that who 'mark as Installed' it will make it easy to him to get updates.
About this hack:
This hack find the advanced options to prevent copies of the topics easily (which i mean source code not easily way to copy topics. This hack leaves several disrupt things in the face when visitor wants copies topic .. see characteristics:
Member groups: the figures which put the groups number you want to prevent them from shading and selecting text..
exclude or add forums: (new!) the figures which put the forum ids you either you want add forums or exclude them... from shading and selecting text.
prevention of shading region: this hack allows you to select the region that wants to prevent shading so the visitor can not copy and therefore have to register if he want to steal your topics ..
Prevent right button: the mouse right button at a pressure of several important orders for example: save target as, or print, or refresh and other orders .. Of course, this option does not disrupt not disrupt versions, so you are not obliged to disable it only if you wants to prevent the theft of images and download links. if you want to allow copies edit figures hack groups or failure of the choice of activating the product.
prevent toolbar images: When activating this option will prevent the toolbar that appears on images when a mouse button it .. And therefore can not control it as member on conservation groups. of course, supports this option toolbar in Microsoft Internet Explorer browsers and simulated, but there are some browsers have different toolbar can not be prevented ..
Forced to use Java: Some intelligent people disable Java Script in his browser and easily copies text. with this option you can redirect people not using java to page that tell him need to activate or Download Java from official site because were not found on his computer ..
Prevent Opera browser: This inexorable browser can not prevent users who use it from copies or disable the right button. this option do another redirect to page that alert user "this browser not allowed here!!.
Prevent quote before x posts: you can add in this option number of the posts you want to prevent your users from quoting before it..
these option work on 3 places: showtheard, printtheard, archive. in archive some options is disable..
Therefore, we can not completely prevent the visitors from copies, but if cover up the entire text of visiting this shortcoming that will reduce the number of visitors and search spiders expelled completely and reduce archiving. so many of sites take off from the way that concealing links and topics.
Installation:
Import XML file (as product): AdminCP > Plugin System > Manage Products > [Add/Import Product]
Versions:
About this hack:
Installation:
Versions:
- v1.0 -
- first release beta.
- v2.0 -
- correcting some phrase with wrong information about java and javascript.
- add option to prevent users from quote before x posts.
- add new javascript code and correct some bad code.
- add option to exclude forums from prevent users.
- v2.1 -
- option added: to choose either you want add forums or exclude.
