![image.png](https://s14.postimg.org/hm8x6s56p/image.png)
Screenshots have always been a part of our daily routine, because with them we have the opportunity to instantly record our endeavors and trifles. It's also a liable means for sharing the passion and experience that we have online and offline with other people. That is exactly what Apowersoft Screen Capture Pro will allow you to do. It also provides best possibilities like ease of use, great editing options and a free cloud storage that you can hardly find anywhere on internet.
Furthermore, this tool features both simple and advanced modes to customize and manage screenshots as you see fit!
Main Features:
- Intelligible and Elegant Ribbon Interface
- Capture anything on screen
- Abundant capture modes for all needs
- Simple and advanced Ways for editing images
- Share Images to social networks in one click
- Free cloud storage for all users
- Robust Task Scheduler for Capture Screen
Elegant and Friendly Interface
Thanks to the great ribbon interface, you are enabled to quickly access the features included in the application at your own convenience. Be it quick snapshot, advanced mode or settings, Apowersoft Screen Capture Pro allows you to utilize all of these through the stunning and reliable interface. Working with it will definitely make you have a high morale and become more productive.
Screenshot Anything Displayed on Screen
There are different situations in which you want to take a screenshot, sometimes you want to capture a single window, other times you need to take screenshots for web pages or for webcams, and you may also need to select the capture area on your own. Moreover, there's the fact that you need to capture screenshots on multiple devices as well. This tool provides you with the unique opportunity to do all of these and much more.
![00224.png](https://s22.postimg.org/sucebtr81/00224.png)
![00223.png](https://s23.postimg.org/zbqw3txxn/00223.png)
-Install
-Do not start.
-Run keygen as administrator -> pach hosts
-Copy crack to install directory
Title : Apowersoft Screen Capture Pro 1.3.1 Build 04072017 Multilingual
File Size : 20 mb
