Plan, model and design your dream home. Ashampoo Home Designer Pro 4 has everything you need to plan, design and preview your dream house in 3D. Smart wizards facilitate data input and get you good results quickly. Create professional-grade blueprints and be your own constructor right on your PC!
Furnishing included
What will your finished house look like? Ashampoo Home Designer Pro 4 includes everything from doors, windows, balconies and carports to sanitary and electrical installations including photovoltaic elements to give you a realistic impression of your future home!
Millions of ready-to-use objects for perfect furnishing results
Ashampoo Home Designer Pro 4 supports the loading and editing and saving of various new 3D object formats. This gives you access to millions of 3D objects! Simply import them and add them to your designs! With support for Google Sketchup or Collada models, you can now instantly use numerous generic and brand-specific models.
Plan photovoltaic installations with ease!
Comfortable input aids help you plan sophisticated photovoltaic systems in minutes. For roof-mounted system, you can already specify their layout, select modules from the object catalog and their placement during the setup phase. The program will automatically determine the settings for the roof as soon as you point at the target side. Once configured, the photovoltaic installation will be added to your plan.
Redecorate and view results instantly
Ashampoo Home Designer Pro 4 is also an indispensable tool for redecoration. Rearrange furniture and decoration and take the virtual tour to make sure everything fits together harmoniously. This spares you nasty surprises and disappointment. Thanks to the huge selection of furniture and decorative items as well as plants, there are no limits to your creativity.
Complex calculations? Let the program do it for you!
Whether it's angle, length, area or volume calculations - you focus on the design, Ashampoo Home Designer Pro 4 does the math.
Fascinating 3D previews
The phenomenal 3D view allows you to take a virtual tour through your buildings - long before the first stone is laid. Move freely through your future home and take advantage of the realistic light and shadow simulation to find the perfect spots for your furniture. Get a glimpse of the way your future projects will look like today!
Fast and intuitive
Ashampoo Home Designer 4 uses a ribbon toolbar that groups all functions logically and thematically. This means you can quickly access each feature and since the program is optimized to make the best use of your system resources, even complex calculations and animations happen in a matter of seconds.
Your vision, your home - perfectly planned
With the new Ashampoo Home Designer Pro 4 your possibilities are endless! Millions of objects importable free of charge help you plan and realize any and every idea. Photovoltaic installations now support roof installations and raster elements greatly facility the creation of 3D elements. Mirror symbols and objects for the perfect fit, calculate areas instantly and discover many more details that will make your work so much easier and so much better!
Requirements :
- Windows 10, Windows 8 / 8.1, Windows 7
- Any computer that runs one of the above operating systems at a reasonable speed.
- Install program (Offline).
- Merge the provided .reg entry.
- Block program in firewall and don't let it go online.
Title : Ashampoo Home Designer Pro 4.1.0 Multilingual
File Size : 1.58 gb
