Ultra powerful zoom function with enlargement by up to 1000%. With 18 zoom settings, Photo Maximizer can tell you the target size of the image in pixels or centimetres. The required resolution can also be adjusted to give you flawless results. This is particularly important when printing your photos and guarantees you the highest quality results.
- Enlarge your photos by up to 1000%
- Ultra powerful zoom with 18 different functions
- Improve quality, clarity and contrast
- Three stages are all it takes - upload, select subject & zoom!
3 Simple Steps!
InPixio Photo Maximizer has been designed to be user-friendly and even includes a helpful wizard.
- Upload an image.
- Select the subject of your photograph
- Select the zoom setting: and that's it!
Before/after comparison
Display up to four different zoom settings simultaneously! Compare the images and choose the best result!
Enlarge photos on your PC, mobile, camera, etc.
Simply transfer your photos to your PC and zoom away!
Zoom your images and maintain extremely sharp edges
Usually when you enlarge an image you get pixilation and deterioration of colour and brightness. Photo Maximizer maintains image quality and undesirable noise. With InPixio Photo Maximizer say goodbye to pixelated, grainy and blurred photos when zooming in.
Batch processing - one thousand photos in one step
Define your zoom settings and Photo Maximizer will batch process up to 1000 images simultaneously!
Print projects
Print your enlarged images as posters, photos for framing, t-shirts, postcards and more.
Discover the possibilities of Photo Maximizer Pro 3:
- Enlarge extracts from your photos with no loss of quality!
- Enlarge entire photos by up to 1000%
- Enlarging photos without Photo Maximizer often results in pixelated images.
- Enlarge photos downloaded from the Internet
- Create poster size prints!
- Enlarge up to 1000%!
New in InPixio Photo Maximizer Pro 3:
- Reduction of typical JPEG pixelation and image interference
- Before/after comparison with up to 4 simultaneous views
- Improved image edges for extreme clarity
- Batch processing - process one thousand images simultaneously
- Multiprocessor operation: for more powerful processing
- Enlarge photos for print projects
-Run InPixio Photo Maximizer Portable.exe
-Use the provided serial to register.
Title : Avanquest InPixio Photo Maximizer Pro 3.0 Portable
File Size : 8 mb
