cFosSpeed 5.12 Build 1652 Final / 5.13 Build 1651 Beta.
cFosSpeed is a network driver, which attaches itself to existing Internet connections. It then optimizes data transfer by means of Traffic Shaping. Traffic Shaping is a method for optimizing the Internet traffic. It allows maximum speed while ensuring minimal Ping. You can use cFosSpeed with a router and/or a DSL-modem or cable-modem. You can also use cFosSpeed with other types of Internet access, ie. whenever you already have an existing Internet connection.cFosSpeed supports a wide variety of connections, like DSL, cable, ISDN, UMTS, etc. cFosSpeed has two goals - keep network delays (ping times) small, in order to make Internet applications as responsive as possible. And improve data throughput by avoiding network congestions. You can use cFosSpeed with an Internet connection you use exclusively or which you share with several PCs.
Connections:
» Broadband: Cabel and DSL
» Narrow band: Modem and ISDN
» Mobile (UMTS, HSDPA, GSM, GPRS, HSCSD)
» DSL, PPPoE
» DSL, PPPoA (VCmux and LLC)
» DSL, PPTP
» VDSL
» Cable
» ISDN
» IP over AAL
» RFC1483/2684 bridged
Routing:» Narrow band: Modem and ISDN
» DSL, PPPoE
» DSL, PPTP
» VDSL
» Cable
» ISDN
» IP over AAL
» Router and dial-up connections
» LAN and WLAN
» Router and Bridge-Mode
» VPN
» Multiple connections simultaneously
» Adjustable routes
» Several IP adresses per adapter
Traffic Shaping:» LAN and WLAN
» VPN
» Adjustable routes
» Multi-User version
» TX and RX-Shaping
» L7 Protocol Analysis
» Prioritization of Programs
» RTP/VoIP Detection
» 5 priority queues
» Individual rules with filter language
» TX and RX-Shaping
» 5 priority queues
(cfosspeed-v512.exe, 3.1 mb)
(cfosspeed-x64-v512.exe, 3.4 mb)Patch để Reset 30 ngày khi hết thời hạng sử dụng Trial (Vẫn chưa tìm ra crack ^^!):
