Gears Of War [2007] -RELOADED + English Lang Fix
HellsBoyz
*Link:
1. Unrar.
2. Install Game.
3. Copy the cracked files located in the Crack directory on the DVD to your
installation directory.
4. Play the game.
If the game starts in Spanish and you prefer playing the game in English,
delete the lang.txt file from \binaries in your installation directory.
Part 1 - 10
Part 11 - 20
Part 21 - 30
Part 31 - 40
Part 41 - 50
Part 51 - 60
Part 61 - 70
Part 71 - 76
*ENGLISH LANG FIX FOR GEARS OF WAR RELOADED and THERMOPYLAE release ***
1) i assume you have the razor's or reloaded startup.exe crack (both works ,maybe the THERMOPYLAE also)
2) open file lang.txt located in ..\Binaries and paste the code 0409 only / then save it.
3) delete the PCTOC.txt and PCTOC_ESN.txt located in \WarGame
4) download this rar:
unrar it and paste the PCTOC.txt in the path before you deleted the old PCTOC (\WarGame)
there are another 3 files (Startup_int.upk +..+..) inside this rar , paste them in path ..\WarGame\CookedPC
5) download this rar
unrar and paste the folder in ... WarGame\Localization (replace the old crap INT folder)
6) download 2 rars here: (66mb+66mb)
part1:
part2:
unrar ,there is 1 folder inside : INT
paste this folder in ... \WarGame\CookedPC\Sounds (replace the 22mb INT folder with this 195mb one)
(by this step you can play the game with eng menus/subtitles in game and SOME english voices. If you take the step 7 you will have all the voices also in game..)
7) FINALLY download these files from:
part1:
part2:
part3:
part4:
RapidShare Links * Updated*
*Working crack
unrar it and paste all the files somewhere temperarily ...
now locate the folder ... \WarGame\CookedPC\Maps
you must paste the correct files in the correct map folders
for example the file SP_Alamo_Cin_LOC_int.war will go into folder SP_Alamo
the file 10_2_CrashSite_CineLevel_LOC_int.war goes to SP_Eba (the only file that doesn't help with the name)
PAY ATTENTION to those maps:
SP_Factory , SP_FactoryBasement, SP_FactoryInterior cause all the files in the rar have SP_Factory and you can confuse things
look where is the _LOC_ESP file and you'll sort things out easily
10) run the game as allways ,with startup.exe (with correct cracks from reloaded or razor)
notice: DON'T START THE GAME UNTIL YOU REPLACED ALL THE FILES
DON'T ASK "HOW DO I PASTE/UNRAR FILES???" !!!
