Hài tết 2011 - Ai Cũng Được Yêu [VOB] [Thăng long Audio]
General
Complete name :
Format : MPEG-PS
File size : 1 024 MiB
Duration : 27mn 13s
Overall bit rate : 5 256 Kbps
Writing library : encoded by TMPGEnc DVD Author 3 Version. 3.0.5.149
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings, BVOP : Yes
Format settings, Matrix : Default
Duration : 27mn 13s
Bit rate mode : Variable
Bit rate : 4 928 Kbps
Nominal bit rate : 8 000 Kbps
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate : 29.970 fps
Standard : NTSC
Color space : YUV
Chroma subsampling : 40
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.476
Stream size : 960 MiB (94%)
Writing library : TMPGEnc DVD Author 3 Version. 3.0.5.149
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 2
Duration : 27mn 13s
Bit rate mode : Constant
Bit rate : 224 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Stream size : 43.6 MiB (4%)
Menu
[/code]
+ Hướng dẫn Dowload: Vao link dow -> click "Regular download" -> click "Download on slow speed" -> doi dem nguoc ve 0 "Wait for Your turn" -> click "Link to the file download" ---> ok!
+dùng Internetdownloadmanager để download
+Cám ơn các bạn đã xem bài viết!
![au4.jpg](http://cb1.upanh.com/19.0.24690250.Wqa0/au4.jpg)
![au5.jpg](http://cb2.upanh.com/19.0.24690251.pqr0/au5.jpg)
General
Complete name :
Format : MPEG-PS
Duration : 27mn 13s
Video
Format : MPEG Video
Duration : 27mn 13s
Width : 720 pixels
Height : 480 pixels
Standard : NTSC
Color space : YUV
Bit depth : 8 bits
Audio
Format : MPEG Audio
Duration : 27mn 13s
Bit rate : 224 Kbps
Menu
![warezs-org_download.png](http://warezs.org/warezs-org_download.png)
[code]http://letitbit.net/download/21864.2e0bf11397b2418fa94d3594546a/_VietTorrent.vn__H__i_t___t_2011_-_Ai_C__ng________c_Y__u__VOB___Th__ng_long_Audio_.part3.rar.html
http://letitbit.net/download/43654.4716441fecfe6cc223e3dbd9563d/_VietTorrent.vn__H__i_t___t_2011_-_Ai_C__ng________c_Y__u__VOB___Th__ng_long_Audio_.part2.rar.html
http://letitbit.net/download/92348.9c644eb409fe1da0270c6ac54202/_VietTorrent.vn__H__i_t___t_2011_-_Ai_C__ng________c_Y__u__VOB___Th__ng_long_Audio_.part1.rar.html
