![image.png](https://s21.postimg.org/j82s81qp3/image.png)
For professionals who like creative control we give them Layers for blending multiple paint styles and brushes to paint on and off the impressionism strokes. We have also included an ultra-impressionism effect called 'Tache' to cover the painting with broken brush strokes or dabs of color that literally stand out, apply them sparsely or cover the entire painting, the choice is yours.
INCLUDES
• Three stroke styles: #1 is a series of straighter strokes, #2 combines the first style with curved ones, and #3 is an abstract set. Then the Tache effect has its own custom set of brushes designed for depth.
• Three Impressionism styles: Alla Prima, En Plein Air and Tache (pronounced tash)
• Pro Layers with built-in Impressionism styles for multi-layer types and options to duplicate, reorder, and delete them
• Control over detail ellipse tool, stroke size, stroke volume, bristle strength & depth, artistic finishes and the painted edge
• Save Preset to save customized paint palettes and keep all strokes & layers intact for future projects
• Smart brushes to remove or add impressionism effect-the brushes are smart because they remove the effect by stroke
• Mask with fill, invert and clear to support brushes and layers
• Canvas and linen texture
• 8 Impressionist palette styles
• One-touch paint styles
• 70 Artistic finishes
• One-of-a-kind ellipse detail tool renders small brush strokes inside the placed area
• Plugin for Photoshop CS3+, Lightroom and Elements for Mac and Windows
![screenshot_20170424_124354.jpg](https://s21.postimg.org/yi2nf8m7b/screenshot_20170424_124354.jpg)
![screenshot_20170424_124722.jpg](https://s21.postimg.org/xh2eq457r/screenshot_20170424_124722.jpg)
-As always, make sure to have a firewall to block outbound connections.
-Install
-Go to Help - > Register
-Use the given serial key to activate (offline)
Title : JixiPix Artista Impresso Pro 1.7.5
File Size : 90 mb
