![icon-app-rip-studio.png](http://jixipix.com/rip-studio/images/icon-app-rip-studio.png)
Rip Studio redefines everything you know about a collaging app. It offers super realistic ripped and cut borders, tape, creased and folded images, and curled edges with full 3D shadowing. All with an incredible interface that seamlessly handles layers while maintaining an easy-to-use workflow. Rip Studio gives you control over every element created inside the app. Rip, tear, or cut edges by drawing around the image. Curl up the edges and wrinkle the surface by simply adjusting a slider. Behind the scene a powerful 3D light engine works to make surface wrinkles and creases look realistic; this adjustable light source will have shadows popping off the page. Finish your creative composition with a tape effect, or choose from a library of objects like stickpins, staples, rusty nails and gems. Every rip you make or tape you place is unique and one-of-a-kind!
Pro Features
Rip Studio is a PRO product featuring layers, multiple selection, 3D light for casting realistic shadows, and the best effects designed for Artists, Photographers and other Professionals who require high-resolution on output.
Rip Studio's edges are fully adjustable and can be customized using Edge Width, Fiber Amount, Fiber Length and Edge Roughness. Once a paper is torn use the image tool to move and adjust photos inside or completely replace the image if needed-this great feature is perfect for creating templates for other projects.
Rip Studio is made for the pro user but easy enough for the novice.
Photo Effects
• Rip - creates hand-torn edges around images and text
• Border - adds an adjustable outline with options for color
• Cut - creates a scissor style cut around edges
• Tape - allows adjustable pieces to be placed, moved and resized
Features
• Rip Effect with control over rip width, roughness and fiber length
• Rip Tool for adding and removing areas to torn and cut paper. Also works on shapes and tape
• Rip Styles to change the look of an edge on-the-fly without redrawing the area
• A cool masking tape, duct tape, cloth tape and transparent Tape Effect. When tape is placed on the edge of the image it auto creases! This can't be done with clip art.
• Masking tape, duct tape and transparent tape with adjustable size, color and surface texture
• Move Image Tool for resizing and moving the image inside a ripped or cut area
• Text Editor for creating ripped, cut, bordered or regular-style letters and sentences
• Smart Layers for composing layouts, collages and easy reordering of objects
• Multiple Selection for moving paper, tape and other objects together
• 36 shapes will auto-cut images into stars, circles, flowers and more'
• 102 high resolution papers
• 18 surface textures
• 62 objects like staples, gems, stickpins and more-with the ability to add your own! All objects placed will create an impression below
• Robust 3D lighting casts realistic shadows-supports multiple light sources
![00207.png](https://s11.postimg.org/61cm97qf7/00207.png)
![00219.png](https://s11.postimg.org/hez5kf0xv/00219.png)
-Install
-Copy crack to install directory according to your system architecture
Title : JixiPix Rip Studio Pro 1.0.7 x86.x64
File Size : 220 mb
