![vegas-dvd-architect-int-400.png](https://s16.postimg.org/h8sl046vp/vegas-dvd-architect-int-400.png)
Create DVD and Blu-ray Discs with professional authoring functions in VEGAS DVD Architect. The intuitive drag & drop interface, compact layout and comprehensive authoring tools make producing menu-based Blu-ray and DVD projects easy.
What's New in Vegas DVD Architect 7:
Professional DVD design
- Use ready-made presets for DVD and Blu-ray projects. Select from backgrounds, menus, buttons and effects to make your videos stand out.
- Alternatively, you can integrate your own Photoshop files for backgrounds, buttons and graphics and create unique DVD designs.
Tons of HD menu templates
- Create your menu from scratch or select one of 100 high-resolution 16:9 menu templates to capture ideas quickly and easily.
- Exclusive to the latest version: 20 new menu templates for even more creative freedom.
Easy DVD preview
- The Preview window enables you to preview your project on a simulated television screen with a virtual remote control.
- Navigate the menus you've created and optimize your project without needing to burn a DVD for previewing.
Burn technology
- VEGAS DVD Architect uses Microsoft Image Mastering API (IMAPI), which offers improved driver support and better stability when burning DVD and Blu-ray Disc projects.
Buttons on video
- Add interactive buttons to your video. This enables you to navigate through your media and jump to a specific scene on a disc.
Chapter markers and captions
VEGAS Pro chapter markers can be directly imported into VEGAS DVD Architect as chapter points. Add a name to each region and export it as a text file. Finally, you can import your file directly into VEGAS DVD Architect and integrate as frame-accurate subtitles.
Parental control
VEGAS DVD Architect contains a variety of settings to prevent children accessing age inappropriate content:
- G - General Audiences
- PG - Parental Guidance Suggested
- PG-13 - Parents Strongly Cautioned - Some Material May Be Inappropriate For Children Under 13
- R - Under 17 Requires Accompanying Parent Or Adult Guardian
- NC-17 - Not Suitable For 17 And Under
Video and Audio Support
- VEGAS DVD Architect supports the latest video and audio formats such as AVI, MPEG-2, MPEG-4 and Dolby Digital 5.1, so you can play DVDs and Blu-rays you create on almost every player or computer.
Keyframes
- Add keyframes to the timeline to animate objects such as buttons and graphics.
DVD scripting
- Create your own scripts and integrate them into your menu. This enables you to create unlimited variations of interactive menus.
![screenshot_20170714_130306.png](https://s23.postimg.org/989ukdbqj/screenshot_20170714_130306.png)
![screenshot_20170714_125951.jpg](https://s18.postimg.org/72n3xgiax/screenshot_20170714_125951.jpg)
![screenshot_20170714_130013.jpg](https://s18.postimg.org/ou3bpnn3d/screenshot_20170714_130013.jpg)
Requirements :
- Microsoft® Windows 7, Windows 8, Windows 8.1, or Windows 10 (64-bit)
- 2 GHz processor (multicore or multiprocessor CPU recommended for HD or stereoscopic 3D; 8 cores recommended for 4K)
- 1 GB drive space for program installation
- SSD or high-speed multi-disk RAID for 4K media
- 4 GB RAM (8 GB recommended; 16 GB recommended for 4K)
- Apple® QuickTime® 7.1.6 or later for reading and writing QuickTime files
-Install
-Copy the contents of the folder "k" in install location (C:\Program Files (x86)\VEGAS\DVD Architect)
-Enjoy !!
Title : MAGIX Vegas DVD Architect 7.0.0 Build 67 Multilingual
File Size : 298 mb
