[MOD VBB]Hiển thị danh sách nhạc của DnP Instant! Musicbox trên Forum Home
iuvothangban
Media Block plugin for DnP Instant! Musicbox on Forum Index
This plugin displays a list of media from DnP Instant! Musicbox on your forum home index page (supports 4 types of arrangement: Newest, Random, High Rate and Most Views). It is a simplified version of the premium plugin . In this free version, however, does not come with inline response (AJAX) and user playlist. It does, on other hand, sport a light and clean pack of DnP Instant! Musicbox fun on your forum home index (and anywhere else of vBulletin pages). Best of all, it does not cost you a dime and supports vB Advanced CMPS.
Installation :
  1. Upload dnp_musicbox_newthread.php to your forum_root (If installed as a VBa CMPS Module, upload to forum_root/modules instead)
  2. Use Product Manager to import product-newmedia.xml
  3. Open Forum Home Templates » FORUMHOME and place
    PHP:
      $dnp_musicbox_newmedia
    to anywhere you'd want the New media block to appear, then save all changes. Done!
Installation for vBadvanced CMPS :
First follow step 1 and 2 in the Installation section above, then go to vBa CMPS » Add Module » PHP File Module. Input the following information :
Module Title : DnP AJAX NewMedia
Active : Yes
File to Include : dnp_musicbox_newmedia.php
Module Parent : None
Templates Used : dnp_vba_musicbox_newmedia
Use Module Wrapper Template : No
Leave everything else by default.
Save the module and add it to your forum page. Enjoy!
Customization :
Several settings can be changed by opening dnp_musicbox_newmedia.php. Reupload the file to your host for any changes that were made.
Enjoy!
