![Syncovery-_Pro-_Enterprise.02.01.2017.header.jpg](https://s30.postimg.org/mjxvx9hht/Syncovery-_Pro-_Enterprise.02.01.2017.header.jpg)
Syncovery - file synchronization and backup software! Your sync and back-up solution is here - now in all-new version 7! Syncovery will copy your files the way you need it. Back up your data and synchronize PCs, Macs, servers, notebooks, and online storage space.
You can set up as many different jobs as you need and run them manually or using the scheduler. Syncovery works with local hard drives, network drives and any other mounted volumes. In addition, it comes with support for FTP, SSH, HTTP, WebDAV, Amazon S3, and Google Docs. You can use ZIP compression and data encryption. On Windows, the scheduler can run as a service - without users having to log on. There are powerful synchronization modes, including Standard Copying, Exact Mirror, and SmartTracking.
Online Backup
We have been backing up our data over the Internet since the 90's, and highly recommend it. Encryption will keep your data safe.
Block Level Copying
Save bandwidth and disk space by copying only the changed blocks of large files.
Real-Time Sync
Real-time sync can be a fantastic speed up for your replication or backup.
File Synchronization
As a generic synchronizer, you can set up our software to fulfill all kinds of tasks, including one-way and two-way syncs, backup, replication, updating or downloading web sites and more.
Profile Groups
You can organize your profiles in groups. Find out how easy this is and how you will benefit from it.
![screenshot_20170608_130753.png](https://s1.postimg.org/kfcwy4flr/screenshot_20170608_130753.png)
-Install
-Go to Help - > Registration
-Use the given informacion to activate
Title : Syncovery Pro Enterprise 7.87 Build 532 x86.x64
File Size : 49 mb
