![Sin_t_tulo.png](https://s17.postimg.org/a7y40dka7/Sin_t_tulo.png)
Quite simply the world's fastest graphics software. Powerful illustration tools, innovative photo editing, flexible page layout and unrivalled WYSIWYG web design. A single application for all your creative work.
What's New in Xara Designer Pro X365:
Stick At Top
By popular demand, you will now have the option for an object to scroll to the top and then stick.
Enhanced 'On Reveal' Animations
On reveal animations were one of the hits of v11. These are animations that are triggered as your object comes into view, and we've added 40 new animation types that work on reveal, such as bounce, zoom and flip.
Parallax Scrolling Effects
The must-have effect for any contemporary site, parallax is a kind of 3D effect created by the background moving at a slower rate to the foreground.
New Scrolling Animations
We also have a completely new type of animation. You'll find 30 'scrolling animations' in the Reveal tab of the web animation dialog, which link an animation to the position of the scroll bar. Instead of the animation running once when the object first appears (like reveal animations), the object animates whenever the document is scrolled, and the speed of the animation is proportional to the scrolling speed.
Other Web Improvements
- A new and improved media player (by default it uses the HTML5 capabilities of the web browser to play the audio and video where the browser supports it, otherwise Flash)
- The preview window has been updated to include MS Edge preview (Windows 10)
Significant improvements since last year include:
- Dramatically improved editing features (add & delete objects, move & resize, add & delete pages)
- Bitmap export & download
- PDF export and download
- Create New Document (yes, your document no longer needs to be created in Web Designer!)
Easy Move, Rotate & Scale for Photos
Select a photo in the Photo tool and you'll see some new handles on the photo, for scale, rotate and crop. It's a lot easier and more intuitive than using the Fill tool for these simple but frequent actions, and it's smarter too - ensuring you never see any gaps around the edge of the photo when you move it in its frame or change the shape of the frame. Top Tip - it's great for horizon straightening!
New Cross Process Photo Effect
Create some dramatic contrast and saturation effects with this new option on the photo enhance toolbar, which simulates a traditional photographic effect created by using the wrong chemicals (digital photo editors such as PGD achieve the same effect by manipulating the red, green and blue channels).
New Blend Modes (dodge and burn)
We've added two great new transparency blend modes, compatible with the W3C standards: Dodge (which generally brightens) and burn (which generally darkens).
Photo Filter Pre-Sets
A wonderfully quick and easy way to apply popular effects to your photos.
You'll find more than 25 ready-made effects in the Content Catalog (image resources > photo filter pre-sets). Simply select your photo and hit Import! What's more you can continue to edit the effects using the Enhance tool or Brightness Levels dialog, and if you replace the photo the effects are retained.
Magnetic Lasso
Cutting an object out of your photo is now as simple as clicking along the edge of the object to be cut, and hitting Cut!
Photo Effect Painter
Check out the new paintbrush tool on the photo fly out. Now you can simply 'paint' on photo effects such as the new dodge and burn. And what's more you can still edit the values of the effect, or edit the painted region with the Region Painter or Erazer.
EXIF Tool Improvements
The EXIF tool has been enhanced, so it now supports IPCT and SMP tags.
Panorama Tool Improvements
Fans of the integrated photo panorama tool will be happy to see some big improvements.
![00515.png](https://s17.postimg.org/7pcezoyjz/00515.png)
- Install
- Copy patch into install directory ( C:\Program Files\Xara\Xara Designer Pro X\12 ) and apply it (as admin)
- Enjoy
Title : Xara Designer Pro X365 12.8.0.50771 x86.x64
File Size : 132 / 155 mb ( x86 / x64 )
